For whatever reason, EVERY example script I have found has failed horribly. JS, BAT, PY every single one of them. I don't even have the first clue how people are getting the damned program to save JS files.... Why can't anyone make a tutorial for JS and PY illiterates? I don't even have the first clue on what I am doing. I've been trying everything I can find on the net for the last 4 days. The only reliable method is doing each and every file individually which means I can do nothing besides sit in front of the computer waiting for each file to complete.I am at my wits end here. I've done the --help and all I can do is look at the resulting info and say "yup, those are certainly commands... HTF do I use them?"
All I want to do is make a batch file so that it will take the video files within a certain folder and just normalize the audio. That's all I want.... Just audio normalization.
Any help is appreciated. Just please don't link me to the tutorial or wiki..... I've tried those many MANY times and no success.
Results 1 to 11 of 11
Are all the files roughly the same specs? ie. same container, 1 audio track, same compression ?
If avidemux isn't working out, you can possibly do a batch with ffmpeg / sox -
General Complete name : E:\Avidemux\Video.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 284 MiB Duration : 42mn 35s Overall bit rate mode : Variable Overall bit rate : 932 Kbps Encoded date : UTC 2013-06-06 18:04:04 Tagged date : UTC 2013-06-06 18:08:01 Writing application : HandBrake 0.9.8 2012071700 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 42mn 35s Bit rate : 767 Kbps Width : 720 pixels Height : 404 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 23.976 fps Minimum frame rate : 23.974 fps Maximum frame rate : 90 000.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.110 Stream size : 234 MiB (82%) Writing library : x264 core 120 Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2013-06-06 18:04:04 Tagged date : UTC 2013-06-06 18:08:01 Color primaries : BT.601 NTSC Transfer characteristics : BT.709 Matrix coefficients : BT.601 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 42mn 35s Bit rate mode : Variable Bit rate : 160 Kbps Maximum bit rate : 202 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 48.7 MiB (17%) Encoded date : UTC 2013-06-06 18:04:04 Tagged date : UTC 2013-06-06 18:08:00
This is example of a batch file. It pipes to sox for the normalization and back to ffmpeg. It's set to normalize to -3dB currently. Change the value to what you want.
Open notepad in directory of files to be converted. Copy & paste the following, save. Rename the .txt to .bat extension. Double click the .bat file
All MP4's will be processed in that directory. The video will be stream copied, but the audio will be normalized and re-encoded with libvoaacenc with 192kbps. Change the bitrate if you want. The new files will be in the same directory with the same name, just the "new" added on to the filename, but you can specify an output path, and you can change the filename if you want
You need ffmpeg and sox. If they are not in the search path (either the same directory or setup as an environment variable) you can change the script to reflect the paths of the .exe files
Code:for %%a in ("*.mp4") do ffmpeg -i "%%a" -f sox - | sox -t sox - -c 2 -r 48000 -b 16 --norm=-3 -t wav - | ffmpeg -i - -i "%%a" -map 0:0 -map 1:0 -c:v copy -c:a libvo_aacenc -b:a 192k "%%~na.new.mp4" pause -
Received the following two errors:
pipe:: Invalid data found when processing input
Could not write header for output file #0 (incorrect codec parameters ?): Error number -22 occurred
